Hi
I have twin 2000 225HP Johnsons and the tilt will not go all the way up on one of the motors.
I works fine to trim and the tilt work like it should except it cuts off just shy of going all the way up so I can engage the trail lock lever. If it weren't for the inability to lower the support lever I wouldn't know anything was wrong and the distance it is shy of full tilt is about 1/2".
Occasionally when I keep pressing the up switch either on the motor or shift lever it will bump up the final 1/2".
Any ideas??
Thanks
Any ideas??
Thanks
