pjcmodem
- Aug 12, 2009
- 6
Hi, I just bought a used motor and I have a couple of questions maybe someone can answer. The motor is like the one in the photos.
The person I bought the motor from made mention of changing the lube in the lower unit because he did not. I removed the two screws at the bottom and nothing came out. Upon further observation, it appeared that there was a cover that those two screws were holding in place and not drain/fill screws. I pulled off the cover and there was no "oil" type lube, but thick grease. Is this correct? What type of grease should I use to re-pack the lower unit? How do I remove and replace the water pump?
Thank you in advance, Pat
