I'm replacing the seals on my lower unit. I put the lower unit back together...put shift yoke into the linkage, propeller shaft in place, replace bearing cage and bolt the upper gearcase to the lower. Everything seems fine, except when i put the prop back on I tried to rotate the prop and it seems to be VERY difficult to rotate. Is this normal?
I found that in neutral, i can rotate the prop with 2 hands but there is a decent amount of resistance. When I shift it into gear i can turn it, but can hear gears clashing a bit. This is just rotating it by hand with no lube in the lower unit.
With the drive shaft in place, the drive shaft will rotate when i turn the prop, but I can't get the driveshaft to turn by turning it manually.
