jpwade_bsu
- Sep 21, 2009
- 28
evinrude model 507125s
I removed the nuts as noted by A & B in the photo, removed the 4 motor mount bolts and all other misc, wires, controls. Flywheel is off. used block and tackel with a good bit of tension on powerhead and rocked it back and forth with only a very minor amount of movement noted in the powerhead studs, powerhead will not break free,
am I missing a bolt somewhere like at the front half of the casing under the carbs pointing towards the rear of the block or do i just need to keep rocking the powerhead until it free's itself?
A. 8 nuts for powerhead studs on port and stb. side
B. 1 nut at rear of powerhead
C. did not remove 2 bolts (told these are for exhaust housing)
D. appears to be a pin in the attached photo or is there a bolt, nut up front ?
Joe
Joe
