I got an old 6hp evinrude lately.The pistons were froze and had not been ran in years.I got everything freed up and turning,just to breath a little life back into it. got it running.I bought a new carb kit for it,but I can't set the carb float no matter what I do.I know to set the float even with the carb body and all that,but nothing seems to work.It runs if you don't sqeeze the bulb to much or it will over flow,so I use that as the choke to get it started.It will run perfectly and even idle pretty good, but very tricky.I wouldn't trust it out on the water.I have come to the conclusion that the needle does not match the seat.I am going to buy another kit ,a different on I hope and try again.Has any of you guys run into this?
