OMS pump failing maybe ???
The good thing is it is using more than enough and not giving you lubrication problems at present. Make sure the tank or oil lines are not leaking into the bilge somewhere though. If not change pump or convert to premix.
Your VRO pump probably needs a rebuild, probably a hole in the diaphragm. There are some test in the OEM manual. Your BRP dealer will have a listing of the rebuildable pump kits.
Thanks for the help. I pumped up the gas bulb and started to see gas leak from the top middle of the vro pump. Looks like it is on the gas side. I think I may need to replace the whole pump.
