Problems with my nx882...
llanda68
I have a Nitro boat Model nx882 Optimax motor with a 115 and has mounted an Laser II propeller 22P and has a lot problems in the output. I know what the proper propeller for not having many problems at startup with the boat.
What is the most suitable propeller for mounting in the boat with this engine?
rs1lollie
Re: Problems with my nx882...
I think this info will help you out:
For safety, and efficient performance, it is critical that your engine operates within the RPM range recommended by the manufacturer.
A change in the prop pitch will increase or decrease the engine RPM's and can be used to bring them into the recommended range. A 2" pitch increase (for example, from 21" to 23") will result in approximately a 300-400 RPM decrease and vice versa.
The correct prop allows the engine's RPM to run within the top end of the manufacturers recommendation.
3 vs. 4 Blade Props
3-Blades
3-blade props are great on most boats as they offer good all around performance, better efficiency, and can achieve higher speeds. Switching from 4 to 3-blades generally requires a 1" pitch increase.
4-Blades
4-blade props work well with bass, pontoon & high performance boats as they provide better acceleration (hole shot), keep a boat on plane with fewer RPM's, and produce less vibration at high speeds. Switching from 3 to 4-blades generally requires a 1" pitch decrease.:)
Ayuh,... Please Explain,... That statement makes little to No sense, at all...
llanda68
Plan for the boat are passengers should be placed on the front of the boat if it does not plan to.
