Your 1970 9.8 doesn't have any points since it' has the electronic stator assembly. If your stator assembly has gone bad, you may not like the price of replacing that part.
Check for spark first. If you don't have spark, troubleshoot accordingly.
Look at the points and give then a quick cleaning scuff with emery cloth and make sure the gap is .020 then give it another pull and check for spark.If that is the case,they are cheap just replace them.
