  #1
Old October 2nd, 2003, 05:23 PM
vonfranken vonfranken is offline
Default leaking front chamber on 18' pontoon
I am also new to boating (2yrs). I've had this tracker marine 18' party barge for 2 yrs and this year the front chmbers on the toons started taking on water (lots). when pulled out of the water it was seeping all along the weld joint. I drilled 1/8th holes on both sides to drain (it took forever) Question?? do I reweld and hope i get all the holes or fiberglass thewhole area. all help apprecited
  #2
Old October 2nd, 2003, 07:44 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: leaking front chamber on 18' pontoon
Re-welding is the only way your going to fix it right. Take it from one who knows!! Been there, done that!
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old October 2nd, 2003, 09:05 PM
93bronco 93bronco is offline
Ensign
my friend has a 21ft tracker, with same problem.he had 1inch holes cut & welded drains at the base of both rear tubes to drain water. he has had both sides front & rear welded so many times that to weld again 1/4 in plates will have to be used for re-enforcement.-must be thin alum that they use for their pontoons.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Leaking Front Seal? Knot Waiting Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 October 6th, 2006 08:07 PM
Fuel still leaking out front of carbs with engine tilted up rickd20006 Johnson & Evinrude Outboards 9 August 12th, 2006 12:39 PM
FRONT OF PONTOON LOW LEMINWV Boat Topics and Questions (not engine topics) 6 July 24th, 2005 01:26 PM
Gas in spark plug chamber Jzervos Johnson & Evinrude Outboards 5 August 7th, 2004 06:46 AM
Combustion chamber Volume ? Boomyal Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 12 January 31st, 2004 03:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
