Re: 1979 Evinrude 9.9 carb adjusting
Take the knob off by pulling it outward and off. Pull the hood off and turn in the screw all the way to bottom it out. Back it out a turn and a half, put the knob on and start from there, it may be close enough to tune. Warn up the motor and get it running smooth with the adjustement knob. Check spark while you are at it, it may not be a fuel issue.
Oh ya forgot you have remove the air box off of the carb to do this, 4 screw from the top, 2 screws inside. When you reinstall you have to push the bottom platic piece against the carb as you tighten the 2 screws.
__________________
 1983 Thundercraft 16.5 * 1983 Johnson 90 v4 * 1983 Johnson 9.9 * 1965 Evinrude 9.5 * 1955 Evinrude 7.5 * 1951 Viking 3 **Latest-76 Evinrude 15
Reason: additional info
