I have a 1990 Chris Craft 167 Concept with a 3L HO OMC Cobra. When I went to change the lube in the outdrive the first thing I did was remove the dipstick on the top of the unit. As soon as it was loose pressure shot it up about a foot and tan colored lube started running all over the place. Removed the plug in the lower unit at the bottom and the same color lube slowly dribbled out. Removed the mid plug and clean lube came out. My question is why the pressure on top and why the clear in the middle?
Thanks,
Matt
Thanks,
Matt
