Re: 30 Mariner Stalls & Dies
try cleaning the carbs, you may have sucked up somthing in your tank and clogged a jet. also check your fuel filter if your carburator is clogged your fuel filter will need to be replaced. or it may be running a cylinder down, check the spark in all your cylinders and compression in all of them
