Checking spark - Using Top Secret File
waynehol
I read this on the TS File:
Electric and manual start: Flywheel rotates but engine does not attempt to start. .
Remove a spark plug, reconnect it and hold it against engine block. Keep it there while turning engine over.
Does it make a hot, blue spark when attempting to start?
If no, troubleshoot ignition system.
Has hot, blue spark?
So, should I use rubber handled pliers and gloves or something? Any danger here? Can I check each individual plug one a time to see if one not working?
THanks,
MidnightSpeedKC
Re: Checking spark - Using Top Secret File
Just hold onto the rubber boot or wire (be sure it's not frayed or has exposed wires)
It shouldn't shock you.
