1st boat, Lighting question?
kdog50
Having trouble wiring my bow light. Switch is a toggle with 3 connections, 2+ and 1-. I have power to the switch but the light will not work.
xxturbowesxx
Re: 1st boat, Lighting question?
If its a light that is removable check voltage at the base if not try replacing bulbs.
boat1010
Use a tester to check for voltage at the light. If no voltage just follow the wires back. Remember there has to be two wires to complete the flow.
kdog50
Thank you boat1010. I will try that again. I'm guessing this should be simple.
boat1010
Yep it is pretty simple, but can be a pain. All you have to remember is that the electricity has to have a path to flow from positive to negative. Just sometime finding why it will not flow can be pretty frustrating. On a car it is pretty simple, you just use the frame for the ground. A boat has to have two wires. Hope that helps. Happy boating.
