'87 Force 50 507X7B
New head gasket, new exhaust gaskets...
With the cover off, muffs on, I can see water in a fairly steady stream from below the exhaust cover assembly at idle. When running on the water, the compartment fills with water. I thought it might be the mating surfaces not matching, so I took the exhaust cover assembly off and put high temp permatex on all mating surfaces and cured for 2 days but the leak is still there.
There are no visible cracks in the exhaust plate or cover. I have found replacements at a used parts outlet, but I suspect that the block is cracked.
There is really no way to get a closer look without taking the whole upper apart.
I guess this is going to be my winter project - to rebuild the entire motor. I can get a used "serviceable" block for $200, but I'm questioning the worth... This is a pretty tall project for me.
I have looked around for a rebuilt power head, but there isn't anything out there at this time, and I'm not sure whether I could afford it anyway.
I have a settlement coming sometime in the next 6-8 months and am thinking about an Evinrude, but that's just dreaming for now.
Comments? Thoughts? I'm starting to wear out...
steve
steve
