  #1
Old September 28th, 2003, 06:34 PM
JTMaclain JTMaclain is offline
Default Painting an Aluminum boat
I have a 1998 14ft weldcraft boat. It still has the original green paint but it looks to be kind of oxidized. Should I prime it before I paint it or just rub it down a little with sand paper?Thanks,Nick
  #2
Old September 28th, 2003, 11:30 PM
walleyehed's Avatar
walleyehed walleyehed is offline
Default Re: Painting an Aluminum boat
I would recommend a healthy soap and water bath before sanding or "roughing the surface", because if at any time the boat had wax on it, you will impregnate the wax into the pores of the aluminum. If there are any un-painted areas on the outside, after the was job, use scotch-brite, not sand paper, and hit every square inch. I would use a good primer such as Dupont's CORLAR 2-part epoxy primer or something simular if you are serious about the finish coat sticking well...Good luck!
  #3
Old September 29th, 2003, 05:17 AM
Major Woods Major Woods is offline
1) Pressure wash it to remove all loose paint.2) Scotch-brite pad all surfaces to rough up.3) Use a comercial paint prep solution to remove all oils.4) Zinc chromate primer.5) Final paint.
  #4
Old September 29th, 2003, 07:19 AM
ratherbefishin ratherbefishin is offline
better to strip it completely- right down to bare metal- why go to all the trouble and expense of recoating it if there is any of the old paint underneath ?This of course, is where all the time and effort goes- so if the boat is worth it,and you want to ensure a good job, you must strip it completely.You can either spend many hours sanding and buffing, or use a chemical stripper.Check out www.napierenvironmental.com for a product line up-water based- doesn't burn your skin, no fumes and biodegradable.Spray it on, leave it overnight and pressure wash it off.This was originally designed for stripping aircraft, so it works just as well on boats.Sure makes the job easier, too, as well as assuring a much better recoating job
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
painting a aluminum boat RUSTY.B Boat Topics and Questions (not engine topics) 1 April 28th, 2005 08:35 PM
painting my aluminum boat jscotty Boat Topics and Questions (not engine topics) 2 July 21st, 2004 08:22 AM
Painting Aluminum boat mattconlon Boat Topics and Questions (not engine topics) 7 June 22nd, 2004 01:10 PM
painting aluminum boat maddog5203 Boat Restoration and Building 7 October 24th, 2003 08:46 PM
Painting aluminum boat Tackle Box Boat Topics and Questions (not engine topics) 5 August 13th, 2003 07:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
