  #1
Old November 4th, 2009, 07:29 AM
crawfisher crawfisher is offline
Smile mercury cooling?
have a mercury 50 hp outboard, not sure of the year but numbers are 9b114042 if anyone can help with that. second, i replaced the water impeller, and when idling it will pee strong, the dwindle to a dribble, then it will go strong again and repeat the cycle. water is so hot you cannot hold your hand in it. when in gear, the stream remains strong. do i have a problem or is this normal?/
  #2
Old November 4th, 2009, 09:46 AM
will941s will941s is offline
Default Re: mercury cooling?
Sounds like it's doing just fine, the thermostat is working. The water coming should be 120 degrees so it will burn your hand a little. I have two merc outboards and as long as the t-stats and the waterpump are working like they should. they only pee when they are hot, or at full throttle.
  #3
Old November 5th, 2009, 12:37 AM
Smile Re: mercury cooling?
thanks for the info. today i ran the motor and noted that the top cylinder did seem hotter than the lower cylinders. also where is a thermostat located on this motor?
  #4
Old November 5th, 2009, 10:20 AM
If the motor is a two stroke, 3 cyl. then it will be on the left side of the engine if you were looking at it from the back. On the left side on the upper portion just infront of the head. Should be a cover with a tube running to the pee hole on the side of the engine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 8hp Cooling Foresterman Mercury & Mariner Outboards 0 September 21st, 2009 06:40 PM
Mercury XR2 Cooling RyanDavidge Mercury & Mariner Outboards 2 November 24th, 2008 10:44 AM
'77 mercury 4hp cooling fergdav Mercury & Mariner Outboards 1 June 4th, 2007 08:10 PM
mercury 500 cooling galvic Mercury & Mariner Outboards 1 August 26th, 2005 03:45 AM
7.5 Mercury cooling torpy Mercury & Mariner Outboards 0 April 29th, 2005 05:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
