Problams with the Switch plate??
mdlee
My trusted friends at iboat:
I am having a problem with my 3.7L Mercruiser 190hp, when I turn the key, nothing happens. If I wiggle the gear shifter the starter will engage, but some times a huge ark will come from what I believe is called the "Switch plate". I found the part on basicpower.com. My question is can I clean the connectors on the old part and maybe fix the problem, or do I need to buy the new one. I am very new to I/o motors, and a little skeptical about just removing the part without some advice..
CheapboatKev
Re: Problams with the Switch plate??
Best advice I can give ya is get a manual..
You obviously have a wiring issue..
There is a HOT wire that comes off the Nuetral safety switch to the ignition..
Sounds like that is wired arse backwards?
Ayuh,... I'd say you've got Bigger wiring Problems,...
The shift switch plate has absolutely Nothing to do with Starting....
It only controls the igntion circuit when Shifting...
Starting is covered by the Neutral Safety Switch in the controller....
mdlee
[I]"""The shift switch plate has absolutely Nothing to do with Starting....
It only controls the igntion circuit when Shifting"""[/I]
I am also having a problem with a loss of fire to the plugs, it is not totally gone, just very week, and some times the motor wont start. I wonder if the "shift switch plate" is causing this... as far as the ark and the wiggling of the shifter to engage the starter, I will get a wiring diagram as suggested
I am also having a problem with a loss of fire to the plugs, I will get a wiring diagram as suggested
Ayuh,... I bet you're in Saltwater,..?? I'd be Suspect of ALL the Wiring.....
mdlee
You are 100% correct my friend. I am in salt water, NE Florida to be exact. The boat is a twin engine,, the starboard motor runs perfect, but this port motor Is rely showing it?s *****. So would you suggest changing the Switch Plate, or cleaning all connections, and giving it another try??
Ayuh,... I'm sorry Bud,... Your there,+ I'm Not,... It's a judgement call,...
Try fixin' it, if you break it, Replace it...
Btw,... The shift plate switches are NLA parts...
mdlee
Thanks for your help,,, I now have a starting point. FYI if you need any carb work done,, National Carb here in Jacksonville just rebuilt my 2 Rochesters, and they look and work like new. They hve a verry nice place.
