  #1
Old November 2nd, 2009, 01:24 PM
kaos420 kaos420 is offline
Default 08 yamaha f150 cooling probs.
my 08 yamaha f150 has no water from the telltale while idling on ear muffs, recently replaced the w.p. impeller and housing, i have heard from some dealers that this is normal on the hose, but the temp alarm sounds after a min or 2, the engine is not to hot to touch, can anyone shed some light on my problem?
  #2
Old November 2nd, 2009, 01:34 PM
sigma sigma is offline
Default Re: 08 yamaha f150 cooling probs.
Are the muffs the square ones by yamaha or the cheap round ones?
Could be lack of water pressure at the hose as well.
Ever run it before on the muffs without a problem????
__________________
Sigma
  #3
Old November 2nd, 2009, 01:41 PM
KC4YIN's Avatar
KC4YIN KC4YIN is offline
You should use the muffs that are rectangular in shape with water feed on both sides. Be sure to rotate the muffs vertically to match the water pickup on the lower unit. That should solve your problem.
__________________
"97" Bayliner 135 Mercruiser-Then
"04" Palm Beach Baydancer 215 150 Yamaha 4 Stroke - Now
  #4
Old November 2nd, 2009, 01:47 PM
its the square ones but not sure if there from yamaha, we have pretty good water pressure, just got the boat not long ago from my uncle who passed away this summer, as far as i know he did not have any problems with the rig, put it in the water once since i've owned it, it was doing the same thing then as it is now which prompted to replace the impeller and housing only ran it on the hose since then for a min or two at a time
__________________
2008 Key West 186 Sportsman
1985 Chris Craft 336 Commander
1999 kawasaki Ultra 150
  #5
Old November 2nd, 2009, 01:53 PM
i'll be sure to try them vertically, thanks
__________________
  #6
Old November 2nd, 2009, 01:57 PM
KC4YIN's Avatar
Do you have water from the tell tale while the boat is in the water?
I had this same problem when I first got my 04 150 and I just probed the telltale hole with a tooth pick and it started peeing like it should.
__________________
  #7
Old November 2nd, 2009, 02:03 PM
have not had it in the water since i replaced the pump(which had some very slight damage/wear). i can pull the hose for the tell tale at the engine side and blow through it with ease
__________________
  #8
Old November 3rd, 2009, 10:04 AM
joe009 joe009 is offline
i have the same engine,and had the same tbl.there are water intakes on the lower unit.one in the front,two on the right side,above the main water intakes,just below the lower unit rim.they must be taped up.
  #9
Old November 8th, 2009, 10:30 PM
Talking Re: 08 yamaha f150 cooling probs.
got her in the water today and she ran great. Smoot, quiet, and 50 mph no problem, thanks again guys!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
hi 1983 175 cooling probs Benny1963 Johnson & Evinrude Outboards 3 March 25th, 2009 12:41 AM
yammi f150 fuel probs? alaska_racer9974 Yamaha & Suzuki Outboards 6 July 12th, 2008 01:28 PM
Merc 7.5 cooling probs Chironac Mercury & Mariner Outboards 3 September 9th, 2007 02:33 AM
'86 70hp Johnson VRO Cooling Probs egalvtex79 Johnson & Evinrude Outboards 1 June 18th, 2004 04:32 AM
Merc 1968 model 39 cooling water probs jerky0 Mercury & Mariner Outboards 0 August 13th, 2003 11:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
