  #1
Old November 1st, 2009, 08:32 PM
jeep187 jeep187 is offline
Default Pontoon Boat Deck Question
My Pontoon Boat has a factory Vinyl Floor. Is it normal to see the seems where they peice the Plywood through the Vinyl? The Vinyl is not cracked or sepperating at the seems you can just tell where they are.
Thanks in advance.
  #2
Old November 2nd, 2009, 09:18 AM
Silvertip Silvertip is offline
Default Re: Pontoon Boat Deck Question
That depends entirely on high tightly the plywood panels were joined when the boat was built. As the boat ages the plywood will shrink a bit so I would expect the joints would tend to show.
  #3
Old November 2nd, 2009, 09:44 AM
EGlideRider EGlideRider is offline
My guess is that it is normal to see the seems.
  #4
Old November 2nd, 2009, 09:15 PM
Smile Re: Pontoon Boat Deck Question
Thanks for the imput guys
  #5
Old November 2nd, 2009, 09:33 PM
cc350's Avatar
cc350 cc350 is offline
My guess on the seams showing would be, water is absorbing into plywood and swelling at the seam causing the distortion of the vinyl/coated decking surface. I'd pull the pontoon and allow to dry then apply a water proofing. Also consider sheeting the under-body with sheet aluminum to stop water saturation from your wake. This also will give you more mph and better fuel usage. a +++
Just a opinion
__________________
2005 Odyessy 322 fc Pontoon 90hp Johnson
1995 Caravelle 1750 BRSE 3.0lx
  #6
Old November 3rd, 2009, 10:04 AM
Quote:
Just a opinion
You can't waterproof the top of the deck without removing and distroying all of the vinyl surface. And you never waterproof the bottom of a deck.
  #7
Old November 3rd, 2009, 05:38 PM
cc350's Avatar
Yes you can waterproof the underside of the plywood. The surface is already covered with sheet vinyl. There are many products out today for doing this with marine plywood. Aqua tech has done this for years and sold many products to do it,penetrating to lite mixed epoxies.
__________________
  #8
Old November 3rd, 2009, 06:18 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Never a good idea to seal up the bottom side of the plywood and is also unnecessary. It needs to be able to breath and shed any moisture that permeates it. Otherwise it will hold the moisture and rot in short order. Now it you seal the entire sheet, with epoxy for example, then that would be fine..
__________________
Rick
"Boating is Life...All the rest is just Details"
  #9
Old November 4th, 2009, 09:30 AM
Quote:
Rickdb1boat's response was much better than mine and very accurate.
  #10
Old November 16th, 2009, 02:12 PM
NCLakeboater NCLakeboater is offline
If a pontoon has the underdeck aluminum wave shield does that prevent the underside of the wood decking to breath, assuming some moisture reaches the plywood?
  #11
Old November 16th, 2009, 03:03 PM
An aluminum shield would not be air tight so it should not present a problem. Maybe a better word for breath might be drain. The real bottom line is that when moisture is in the wood, it must be able to drain out the bottom. The more free air flow, the easier for the moisture to exit the deck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pontoon Boat Speed Question jeep187 Pontoons 5 October 18th, 2009 03:19 PM
deck boat or pontoon ? mtpawn Boat Topics and Questions (not engine topics) 9 January 31st, 2008 10:47 AM
Pontoon boat - new deck and interior afphinfan Boat Restoration and Building 9 October 8th, 2006 08:55 AM
Pontoon or deck boat for bay use? gbenmc Boat Topics and Questions (not engine topics) 6 May 7th, 2006 01:00 AM
Removing carpet from pontoon boat wood deck geezer1960 Boat Restoration and Building 2 March 14th, 2005 12:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
