Re: Tach Installation
It doesn't actually hook directly to the engine. The wires from the dash will go back to the big plug on the motor. Then on the motor, the wires from that big plug go to the various things on the engine. (Mercruiser and VP engines are sort of Plug and Play. If you can plug in the big plug to them, they'll work in any boat.)
Tachometer wires should be on the backside of the distributor. And I think one will be purple.
