  #1
Old November 1st, 2009, 08:08 AM
ilabmax ilabmax is offline
Default 2000 40 HP Mercury Force - reverse problem
I have a 2000, 40 HP Mercury Force that lost reverse after shifting into reverse with high RPMs. I imagine something broke in the lower unit. Shifts into forward OK, chatters a bit in neutral. It is still in the water, and I'm wondering if running it in forward might destroy the gears. Any thoughts or ideas about what damage I did, and should I paddle to the trailer and pull apart the lower unit without running it?
  #2
Old November 1st, 2009, 07:54 PM
wellsc1 wellsc1 is offline
Default Re: 2000 40 HP Mercury Force - reverse problem
As the saying goes, "if it ain't broke, don't fix it." Here my compliment version. "If you think it's broke, don't keep running it to be sure." Little things can "explode" into big things. Fix it while it may be a little thing. mtcw
__________________
Carl
Carolina Skiff 175 Sea Chaser, 90hp Yamaha 2-stroke
River City Marine 14' AL flat-bottom, 40hp Force 2-stroke
  #3
Old November 2nd, 2009, 07:51 AM
Here's the authentic compliment to the first quote. "An ounce of prevention is worth a pound of cure."
__________________
Carl
  #4
Old November 2nd, 2009, 06:40 PM
Thanks - I think you have the right idea.
  #5
Old November 3rd, 2009, 10:56 AM
jackd1023 jackd1023 is offline
I had this problem with my older 94 ish 75 hp. It kicked into gear while warming up then I lost reverse. The shift shaft somehow jumped from the knuckle for lack of a better or correct term. I dropped the LU and put the shifter in forward found forward in the LU and reinstalled. There was some play in the shaft found out that it was missing a washer that held the shaft tight. The shaft for some reason would move up and down aprox 1/4 inch. The washer did the trick 5 years later my friend that now owns the boat still has had no problem. Something to check.. hope it helps.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
120 Force Reverse Problem Divedog Force & Chrysler Outboards 4 October 28th, 2009 09:57 PM
Mercury reverse problem joeveebee Mercury & Mariner Outboards 0 June 22nd, 2005 07:14 AM
Force by mercury 120 reverse problems Brentray Mercury & Mariner Outboards 2 April 27th, 2003 04:42 PM
Mercury 850 (1974)/ Reverse problem texas15 Boat Topics and Questions (not engine topics) 1 June 15th, 2002 05:24 PM
2000 Mercury 8 HP problem warlo_527 Mercury & Mariner Outboards 5 May 29th, 2002 12:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
