I am have a terrible time starting my motor. Typically leave it tilted out the water after use. Next use it will just not start. Occasionally it fires right away, other times I can wait ten minutes and on other occasions all day. I have been told that it is the mercury tilt switch??? Any ideas on how to remove this?
I am on the chesapeake bay and rock fish season is here.....!
There is not one to my knowledge ,only on the older Mercury motors. You have the Johnzuki motor and sounds like a fuel problem. If you are using ethanol blended fuel the needle could be sticking in the VST not allowing fuel into tank when trimmed up. Bulb would pump up and stay hard as fuel could not enter tank. Do you hear the fuel pump run when you just turn key on?
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
the trim limit switch prevents the motor from starting when its tilted up.
when its tilted down doesn crank at all?
or does it once in a while?
you know i believe you just could have a bad ecm ground
the ecm knows when you want to start the motor and grounds the solenoid to crank the starter.
if you have a bad ground it stops right there
that could be intermittend. loose or dirty.
I hate to disagree but engine does not have one!! The tilt limit and ECM has nothing to do with starter, you most likely has a neutral safety switch sticking or out of adjustment in remote control. It also could be a bad/loose connection on starter relay or bad relay. If needed can post the diagram and troubleshooting flow chart for that engine
__________________
Fatzbullet, please post the diagram, I believe that you are close to the truth. the reason is I have been able to get the starter to react with the motor fully tilted. Not suggesting that I ran the motor like that though!
I have a technical guy coming over next week, but would prefer to avoid the expense.
