ifallsguy
- Sep 12, 2009
- 160
I am trying to change out the timing belt on my 89 Bayliner Capri with OMC/Ford 2.3L. The manual says pull the bolt and washer (done) and the pulley pulls off, no tool required. I cannot get the pulley to budge. I've tried Kroll oil on the theory it is rusted in place, but after tapping with a hammer, there is still no movement.
Anyone else have this issue, and how did you get the pulley off? It needs to be pulled to remove a nylon washer and then swap belts.
HELP!!! As it sits now, I cannot even (the hated word) winterize the engine.
