Help. Quick. Lube for alternator rotor 470
natemoore
Master Chief Petty Officer
I just threw out an old tube of "Chicago Manufacturing and Distribution Co. anti-scoring, extreme pressure Lubricant No.3" the other day, and low and behold, I need it today.:mad:
Just kidding. Can I use Perfect Seal on the crankshaft end and inside diameter of rotor? Or 2-4-C grease?
Gun oil??? It's gun oil! Maybe I have a bottle of CLP stashed in a dufflebag somewhere.
Don S
Re: Help. Quick. Lube for alternator rotor 470
It's a press fit. (NOT a hammer on fit, use correct tool) A bit of oil on the shaft and bore to prevent galling is all that is needed.
natemoore
Thanks. I did manage to borrow an installer.
natemoore
And of course the Snap-On harmonic balancer installer doesn't work. I made one out of all-thread, a piece of pipe, a few fender washers, and three nuts. Worked well.
