Mounting transducers
skymarauder
Is it possible to mount 2 transducers to the transom (one on each side of the motor) without the two interfering?
Capt'n Chris
Re: Mounting transducers
If mounting that far apart, as you have described, probably so. I say probably because if they are operating on the same frequency simultaneously, it's anyone's guess if they will interfere with one another. Some have success ...many others do not. If operating on different frequencies simultaneously, you should experience no interference issues.
http://www.youtube.com/watch?v=7AIVGy7_A60
skargo
Banned
I have 2 ducers, one shoot thru, the other transom mounted, but on the same side. I only experience interference at high speed.
HAV2FISH
I have two on the back of my boat and also only have interference with the one on the left side when running at high speed. However i found that the interference was coming from the prop wash and not the other transducer. Just mount them as far apart as possible and you should be fine.
skargo
Banned
How did you determine the cause? I only get interference on my shoot thru at high speed, not sure if it's turbulence or the other signal.
diesel5599
That's easy, turn off the fish finder connected to one and see if you still get interference.
I only have one but I get interference at high speed also due to cavitation. I shoot through hull, was far worse when it was transom mounted.
skargo
Banned
:D That makes sense.
HAV2FISH
And thats exactly how i did it. Just turned one off.
skargo
Banned
LOL, talk about a brainfart. :redface:
