Brian McKee
- Sep 12, 2009
- 14
Hello, Everyone!
While wandering about this wonderful site, I chanced upon serial number info that got me wondering about my own little Evinrude. I went out to the shed and when I turned the motor towards the sun in order to get the last five of my serial number, (35082), my left hand came away from the lower handle, (the one nearest the high/low speed knobs), with black oily gasoline on the tips of my fingers. I immediately checked the vent and fuel flow knobs and they were both closed. I am now quite concerned about my little guy.
I just bought this motor for fifty bucks and am determined to restore it this winter while attempting to enjoy its offerings through the fall season. It has not ran for fifty years I've been told and was inspected by a small engine repair man and given a thumbs up before I bought it.
The only major issue was the fact that it had been painted over (with a brush) in a brown that I will not describe here. Now, this is in doubt until I can discern why I have gasoline on the handle while it is stored upright in my shed. It is transported on its side while loaded in the boat since I must utilize the bed of my pickup until I can purchase a small trailer. But, with that said, there was no gas on my hands when I removed it from the boat and put it in the shed, so this occurred over the past three days while stored upright.
The only thing I'm aware of, (that might be at work here), is the fact that I did remove the copper fuel line in order to remove the filter for inspection and one was not found up inside the tank due to a lack of proper tools and initiative on my part. I did however, reinstall the line and tightened it down as best I could and the engine has ran for hours, on two seperate occasions, since my tinkering took place. I have not checked the connections since.
If any of you have suggestions concerning this issue, I would be indebted to you. The only repairs I have made have been the installation of a new starter cord and a shear pin on the prop shaft.
Thanks for your kind attention to this matter!
Brian
Brian
