Bought this unit last year. Power head has about 10 hrs since rebuild. I have tried every imaginable combonation to start this engine cold (no starting fluid) and I still have problems. This is one of the idle on two run on four units. During starting it does not seem to matter how long the choke is held, override throttle position, pump bubble, nothing seems to help. It's gonna start when it's ready. Once running, all seems to be good. Accelerates good, transitions good. I usually make about a 10 min. run then fish about one hour then move. Starts great the rest of the day. The last boat I had was 14 ft. with a 85 HP Chrysler Charger and yes it had a combonation to start, but it worked every time. I am a technical person and rebuilt this Chrysler power head myself and it worked well. I am not sure if this "drip choke" solenoid system is working or not. When engine does start it does not smoke excessively or act like it is flooded. I have checked the timing per the crappy Clymer manual I have and have it set dead on. Bubble pumps up hard, fuel filter is clean, fuel is good. What am I missing? Thanks in advance.
