my next ? is i hooked up my battrey to the motor(fully charged) and it barley turns it over does this motor require a heavy duty battrey w/850 cranking amps or is it a 24 volt system?
You need to clean all of the connections at the engine side and the battery side. High resistance will cause this to happen.
If you don't know the condition of the battery, take it to Pep Boys, Autozone or Walmart and they will check it for you. (and sell you another if it is bad )
