  #1
Old October 28th, 2009, 11:20 PM
Fish'n Lewi Fish'n Lewi is offline
Default Extra wiring in the bow
Hey all.....I have a 06 v16 SC and there is a set of wires up front behind the panel on the bow where the trolling motor power is connected. I have talked to the dealer in my area and they were no help so I called the customer relations # for tracker and was told that the wires should be hot and they would be for connecting a depth finder in the front of the boat which is what I am trying to do. The wires are black and a red with blue/purple stripe. I cant for the life of me see this wire under the console anywhere but it does run back that way to the console. It isn't connected into the fuse panel either so is it in the wiring harness somewhere?
I have ran my own wire up front for a depth finder and connected it to the fuse panel and everything works fine but would really like to use the other wires that are installed.
any help or ideas would be sweet on what else I can attempt.
  #2
Old October 29th, 2009, 01:20 PM
browns44 browns44 is offline
Post Re: Extra wiring in the bow
Hi
If these wires are for the Trolling motor the wires should lead to the wiring harness to the fuse panel then back into a wiring harness that leads to your batteries. Sometimes they place these wires behind the fuse box "top" where you can't see them very well. Tale a closer inspection of your fuse box.
browns44
  #3
Old October 29th, 2009, 02:32 PM
Default Re: Extra wiring in the bow
May have not been too clear. They are not for the trolling motor, I was just saying that is where I found them up front. There is just 2 wires that go to the front of the boat and are ready to be connected into something and are ran with the nav light from the console. I just cannot find the wire (red with purple stripe) under the console and I know for a fact that it is not hooked into the fuse panel.
  #4
Old October 30th, 2009, 01:40 AM
dabalone dabalone is offline
I believe the trolling motor wire has a inline fuse or circuit breaker back where it connects to the battery, possibly the wire you can't find at the fuse panel has a inline fuse also.
  #5
Old October 30th, 2009, 07:18 AM
EsoxRanger EsoxRanger is offline
Tracker has no schematic for the boat? Any power up there that is not for the trolling motor would most likely be coming from the crank battery VIA the console. DOes that boat have a fuse labeled accessory that is powering a bus the wires in question are hooked to?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Stator wiring to extra wire on 1985/85hp force shawpdx1 Electrics, Electronics and Trolling Motors 1 July 9th, 2009 10:26 AM
extra power baileys Boating, Activities and Destinations 2 March 30th, 2005 04:18 PM
Bud Extra ???? jsfinn Dockside Chat 6 February 28th, 2005 02:37 AM
Somebody got an extra Mariner 30? rons boat Mercury & Mariner Outboards 3 January 1st, 2003 08:21 AM
Extra gas tank stemar Non-Repair Outboard Discussions 4 February 2nd, 2002 02:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
