October 28th, 2009, 12:48 PM
1964 Evinrude, Model#28402M, s/n #E02487 a hole above gearcase housing.
I want to insert Pictures from cell phone but, unable to do it yet.
By the way by comparing 1962 johnson motor to my, there is no hole on Johnson. My has 2 # 14 holes, 1 of # 24 which is for pivot assembly,
And 1 additional hole right above gearcase housing, it is strange compare to 1962 Johnson RX,RXL-10c.
please help, Thank you.
October 28th, 2009, 01:15 PM
Re: 1964 Evinrude, Model#28402M, s/n #E02487 a hole above gearcase housing.
Probably just a drain hole, to let water drain when the motor is unused.
__________________
Jim
October 28th, 2009, 02:01 PM
Again, you are confusing us. You should have continued on the thread you started yesterday.
http://forums.iboats.com/showthread.php?t=360833
__________________
'77 Crestliner Voyager Dlx 16, '81 Johnson 25hp
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Hole in Int Housing stringer 800 83 model |
studdy05 |
Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives |
1 |
July 19th, 2009 01:11 AM |
| drain hole or chunk of housing missing? 73 evinrude |
BIGcarpy50 |
Johnson & Evinrude Outboards |
2 |
August 6th, 2008 06:32 PM |
| 1964 Evinrude 75hp, repairing thermostat housing |
Evinrude Boater |
7 |
June 7th, 2008 07:16 PM |
| 1964 3 HP Evinrude (model #3402) Can't get a spark. Please help a newbie. |
swimscubasteve |
28 |
March 14th, 2005 06:55 PM |
| Oil Seeping from Gear Housing Hole (Model I) |
Rhadley |
13 |
June 11th, 2004 01:59 PM |
