  #1
Old October 27th, 2009, 11:25 PM
SQUIDLIPS83 SQUIDLIPS83 is offline
Default Fuel Filter Element for Yamaha F115 - Aftermarket Alternatives?
I own 2 x Yamaha F115s (2004) and wanted to know if anyone out there is aware of an alternative (after market) manufacturer for the two small (large thimble sized) fuel filter elements that are located under the engine cowlings.
The Yamaha Parts website at www.yamaha-motor.com/outboard/parts/home.aspx shows their part number as 68V-24563 but it doesn't give you a price and directs you to visit your nearest parts dealership to buy them. This part number has not changed since the F115s first came out in 2002.
I asked a mechanic how much they run and was told they are $24 each (a huge ripoff), so I want to see if Sierra or any of the other aftermarket manufacturers are making a cheaper substitute.
Thanks.
  #2
Old October 28th, 2009, 09:40 AM
robert graham robert graham is online now
Smile Re: Fuel Filter Element for Yamaha F115 - Aftermarket Alternatives?
You could install a Fuel/Water Seperator-Filter(Walmart $27) on your transom and forget those little plastic under-cowl screen filters. The big cartridge stops all the trash and water before it gets up to the little filters. I still have my under-cowl filters but there's never anything at all in them. Good Luck!
  #3
Old October 28th, 2009, 10:48 AM
joe009 joe009 is offline
Default Re: Fuel Filter Element for Yamaha F115 - Aftermarket Alternatives?
i have the f 150,external fuel/water separator on the transom,and the filter inside the motor.i know it is a rip off,but that filter is made for that motor and and it is not a good idea to screw around with it.
  #4
Old October 28th, 2009, 11:13 AM
My motor is a 1999 Yamaha and it still has the original little plastic filter/screen under the cowl, just take it off occasionally, clean it, blow it off and replace it, don't know why you'd ever need to replace it unless you tore it up somehow getting it off. It's not a disposable item like with the cartridge filters, but if I ever need one I'll have to get it from Yamaha because it's a specially designed item. Like I said, since installing the fuel/water seperator, never have anything in the little filter anymore. I still drain my carbs just to be dead sure. Fuel system preventive maintenance is a good idea. Good luck!
  #5
Old October 28th, 2009, 02:45 PM
Woodnaut's Avatar
Woodnaut Woodnaut is offline
Quote:
Originally Posted by robert graham View Post
...since installing the fuel/water seperator, never have anything in the little filter anymore...
Same here. Using a high quality external filter that you maintain properly is essential (especially for high pressure fuel systems). When replacing stuff under the cowling I always use the factory stuff for three reasons: It fits, a new outboard is really expensive and I don't ever want to replace one early, and I like to zoom around offshore (which means there is no room for errors).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Recommendations for aftermarket fuel filter / separator kit BeaufortTJustice Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 24 November 9th, 2009 05:05 PM
Alternative Oil Filter for Yamaha F115? jrsnyder79 Yamaha & Suzuki Outboards 7 October 27th, 2009 11:02 PM
F115 Stock Fuel Filter Yamauser Yamaha & Suzuki Outboards 5 May 7th, 2008 03:19 PM
Yamaha F115 Fuel Filter Question Striper Blues Yamaha & Suzuki Outboards 4 July 7th, 2006 05:43 PM
Yamaha F115 & Raycor Filter alumacomp Yamaha & Suzuki Outboards 1 September 26th, 2005 08:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
