Hey everyone, I am doing a bit of trouble shooting on my fuel gauge and having some issues. Issue one, IT DOESNT WORK HAHA. Well I have a 1977 Marquis tri hull with an evinrude 85. The tank is an 18 gallon tank and has a new sending unit. I measured the tank and cut the sending unit arm to length like the instructions. I purchased a new gauge and cannot get it to read. It has a ground that goes to ground on my wiring block and also a ground that comes from the tank. A red wire to the sending unit that goes to the S terminal on the gauge. A wire that goes to the light hooked up to my headlight switch. And the power wire comes from the ignition switch that sends power to the gauge when the key is turned.... Any trouble shooting ideas? My "fluke" meter said I had about 10.4 volts at the sending unit.... Thanks!
