Hi All,
New to forum and there is an amazing amount of information here - fantastic.
I have a 1988 100hp Merc that everything related to the power tilt and trim works fine but in both tilt and trim mode the engine will drop slowly over time to the lowest position. When the boat is under way and the system is under a load the trim will drop faster than if the boat is going slow or stopped so the load placed on the pistons seems to dictate how fast it falls. The sytem is not leaking fluid, its full of fluid and properly bled. I'm constantly re-trimming the engine up for optimal running angle. This is the 3 ram system with one tilt cylinder and two smaller trim pistons.
Below is a link to the unit in question. I'm looking for advice on either how to troubleshoot it or what parts might need to be replaced. Thanks.
http://www.boats.net/parts/search/M...nts(Three Ram Power Trim Design I)/parts.html
