New outboard on pontoon
crosman
Repowering my 20 foot pontoon with a 2010 mercury 4 stoke 50 hp. What size prop should i get and does it matter that its not a bigfoot. Stealing it at $4852 out the door installed.
steelespike
Re: New outboard on pontoon
There was a post here about a non big foot 50 on a pontoon.He couldn't solve a ventilation(cavitation) problem. and decided to go with a big foot.
While a big foot is well suited to a pontoon application I do believe his venting problem was the exception.most stock motors will do fine on a pontoon with a careful setup.Definately use a pontoon dedicated prop.
Sometimes refered to as a 4 blade elephant ear prop.Height and trim on the motor will be critical.You should be able to try props till you find the right one.
My guess is around 12" pitch.If your dealer works routinely with pontoons he should have an idea what you need.
Silvertip
Honorary Supreme Mariner
I sincerely wish you luck with the non Big Foot motor. You may get lucky. The Merc engine brochure goes to great lengths explaining why Big Foot motors are recommended for pontoon and barge service. The main reason is that they sit lower in the water, can swing a 14 inch diameter prop and there are pontoon specific props for that gearcase.
hwsiii
cros, everything that Silvertip stated is 100% correct. But if you do get that motor or you already have bough it, fill out this form and I will try to help you.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the maximum recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make. manufacturer and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing then do the same thing on the motor and turn the motor until the tape lines up with each other on the prop, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches, use a board under the keel and stiking out to the anti ventilation plate for a referene
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for $ 50
RPM ___________ Speed ___________ No. of people ____________ Gas ________
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
