So I bought a boat from a friend knowing that the motor was stuck in forward. He thought the shop he brought it to for an estimate said it was a coil. The guy at the shop can't remember. So.... I am here to seek some answers to a few things.
The motor is a 55hp Johnson model TRL-10R, looks great and has low hours. It sat for some time before my friend got it. He had the carbs cleaned, a tuneup done. He did get it to fire up once when he had it, then it sat for 2 more years.
First off, the internal engine wiring harness is in bad shape. Cracking, fraying, corroded... So after checking all the connections from the console to the battery I tried to start it up. It just pops and then wont do anything after that until I disconnect the battery and reconnect... then another POP!. I am sure it is a bad wire/missing ground/something.. does anyone have any ideas?
Second, as a result of the wiring harness I am wondering if that is why it wont shift. I haven't tested the wires yet(a rookie at this and need to get the tools for that).
In the end, I like the boat and motor and would like to make this a project.
So I am thinking about ordering a new coil, wiring harness and an amplifier cd pack. Just to get things top notch.
Are these parts something worth while for me and could I do it myself?
Thanks much
Thanks much
