  #1
Old October 26th, 2009, 10:14 PM
FlyBoy1976 FlyBoy1976 is offline
Angry 1954 Evinrude Head Gasket Replacement
I have been restoring a 1954 Evinrude Fleetwin 7514 7.5hp. I finally have made it back to the Power head and was replacing the head Gasket.
Now here is where my problem comes in the manual says I need 90 - 95 inch pounds on these bolts. When I tighten them I get maybe to 20 on my torque wrench and they seem to give way. And I may have just solved my own dilemma as my torque wrench is in foot pounds not inch pounds, which means I way over torqued the ones I put in. Can I just re-tap the ones I messed up or do I need to do something else to fix this now?
Thanks for any and all help.
  #2
Old October 26th, 2009, 10:17 PM
bktheking's Avatar
bktheking bktheking is online now
Ensign
Default Re: 1954 Evinrude Head Gasket Replacement
Are you saying you stripped the threads in the power head? Sounds like it if it called for 95 inch and you put 20 ft. You will probably have to drill them out and helicoil them with an insert. I've never done one, maybe one of the experts on here can explain.
__________________
1983 Thundercraft 16.5 * 1983 Johnson 90 v4 * 1983 Johnson 9.9 * 1965 Evinrude 9.5 * 1955 Evinrude 7.5 * 1951 Viking 3 **Latest-76 Evinrude 15
  #3
Old October 26th, 2009, 10:23 PM
samo_ott's Avatar
samo_ott samo_ott is offline
Yep. Drill em and retap next size larger. You should be able to do it without heli coils. And the aluminum is soft and easy to so. 95 inch pounds / 12 = ~8 foot pounds. Not very tight at all.
__________________
Steve.
  #4
Old October 26th, 2009, 11:40 PM
stingertrey stingertrey is offline
This is really helpful i have been wondering what the correct torque on the head bolts
  #5
Old October 27th, 2009, 02:04 AM
Smile Re: 1954 Evinrude Head Gasket Replacement
Thanks for the quick replies I will try to get that done tomorrow. It may be a bit of a pain, but doesn't sound to hard.
Just for clarification the bolts were 1/4 - 20, 1 1/2 inch so the next size to step up to I believe would be 3/8 - 20?
Thanks again for the help.
  #6
Old October 27th, 2009, 03:56 AM
F_R F_R is offline
Nope, the next size is 5/16-18. Or maybe a Metric? I'm not up on Metric stuff.
However, my opinion is that you should install Heli-Coils. By the time you drill the holes in the head out to 5/16" + clearance, isn't the material around them going to be mighty thin? With Heli-Coils, you use the original bolts. Besides, seeing 5/16" bolts in there would arouse an instant suspicion that a shade-tree has been working on it and will destroy the originality and value of the motor. Right now you have a classic motor of interest to restorers. Cobble it up and you will have just another pile of aluminum. If you are going to do something, do it right.
  #7
Old October 27th, 2009, 10:14 AM
samo_ott's Avatar
That's the other method. Personally I'm not that keen on heli coils. I find they pull out over time. But now you have 2 different options.
As for the 5/16" bolts? They can have the same head size so not noticeable. and usually there's lots of material around the bolts to drill out... anyway... Your choice... or maybe others will weigh in...
__________________
Steve.
  #8
Old October 27th, 2009, 10:35 AM
bktheking's Avatar
Ensign
Samo, then you haven't been installing them right. Helicoils are stronger than tapped threads and if done right will last a lifetime. If you are worried about it send the block into a reputable shop and have them installed.
__________________
  #9
Old October 27th, 2009, 06:04 PM
jay mendoza jay mendoza is offline
Be sure to drill out the holes on a drill press so they are straight. You can then either re-tap for 5/16-18, or Heli-coil inserts. Be sure to use a bottoming tap for the inserts so the treads don't have a taper at the bottom of the hole, that would cause the Heli-coil inserters to bet tighter at the bottom once installed and cause the head bolt to bind in the threads.
If you go with inserts the only drilling will be in the block. If you go for bigger bolts, be sure to clearance drill the head, and holes in the head gasket as well for the larger bolts. You may want to check and see if there is enough meat around the holes before you decide which way to go.
  #10
Old October 27th, 2009, 08:33 PM
samo_ott's Avatar
Quote:
That is quite possible! And the main reason I like to over drill and tap. It's easy and always works and relatively cheap.
__________________
Steve.
  #11
Old October 27th, 2009, 10:00 PM
bktheking's Avatar
Ensign
I agree, sometimes you can't and have no choice but to coil them, oil passages and water jackets and everything else can get in the way. Winter's coming, good ole Ottawa.
__________________
  #12
Old October 28th, 2009, 01:19 AM
1946Zephyr's Avatar
1946Zephyr 1946Zephyr is offline
7 millimeter is .276 diameter, which won't give you enough thread. 8 millimeter is .315 so if you go out to a 5/16" that would actually be safer. You'll have to tap it out larger for a helicoil anyways, but you'll have steel thread inserts, instead of aluminum threads, so it'll actually be stronger and less likely to be seized up years down the road. Use the 640 locktite and they'll never come out in a million years. Just make sure that you let it set up for several hours before you put a bolt in it, incase some gets on the inside portion of the threads
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1964 Evinrude 5.5 Head Gasket Replacement Questions n8turefreak Johnson & Evinrude Outboards 0 July 21st, 2009 08:04 PM
head gasket replacement boatwrecker10 Johnson & Evinrude Outboards 1 June 4th, 2009 03:02 PM
1975 6 hp head gasket replacement -dry gasket? BF Johnson & Evinrude Outboards 11 July 3rd, 2007 01:46 PM
Head Gasket Replacement????? schonn Johnson & Evinrude Outboards 8 May 8th, 2006 12:26 AM
Head Gasket Replacement as PM John from Madison CT Yamaha & Suzuki Outboards 3 December 10th, 2004 11:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
