  #1
Old October 26th, 2009, 07:19 PM
SWIFT HALF SWIFT HALF is offline
Default 15 hp evinrude cooling problem and id
hi i have just brought a avon 12 foot plus a 1 hp evinrude i was told it was an 80s model but when i have put the model number in the net cant seem to find the year the number is[be15balcob] can anybody id the year so i know what im ordering in parts . now to the cooling problem i put it in the water today and found it had no water coming out the pee hole phoned the guy who i had it off and he said it could be blocked and to stick some wire up it to clear it did this but found a small drible of water but then it stoped so i turned the outboard off as it was not cooling any advice please thanks matt
Don't know what you changed, Matt, but this is what I meant:
Hi. I have just bought an Avon 12 foot plus a 15HP Evinrude. I was told it was an 80s model, but when I have put the model number in the net I can't seem to find the year. The number is BE15BALCOB. Can anybody ID the year so I know what I am ordering in parts?
Etcetera. Editing the whole post is more work than I am up to this morning.
  #2
Old October 26th, 2009, 07:47 PM
JB's Avatar
JB JB is offline
Default Re: 15 hp evinrude cooling problem and id
First piece of advice: Please spell, punctuate and capitalize your posts as you were required to pass grade 5. It make them much more readable and you are much more likely to get serious responses. As is, your post tells people that you are either illiterate or don't give a hoot about details. Neither inspires a response.
I think your engine is a 1985 Belgian made, long shaft.
__________________
RED SKY at night. . .
JB
  #3
Old October 26th, 2009, 07:50 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
BE=Belgium made
15=HP
BA = AC Lighting - Rope Start
L=Long Shaft (20")
CO=year 1985
B=Model run
I would suggest replacing the water pump if it's unknown when it was last done..
__________________
Rick
"Boating is Life...All the rest is just Details"
  #4
Old October 26th, 2009, 08:44 PM
Said by the man sat on his porch playing the banjo with his teeth falling out and holes in his shoes .
  #5
Old October 26th, 2009, 08:46 PM
thanks for the advice mate will do now i know the year of production .
  #6
Old October 26th, 2009, 09:09 PM
bktheking's Avatar
bktheking bktheking is online now
Ensign
Quote:
Dude how did you know JB played Banjo??? Him and I have a Banjo band in Texas together, you know down there in the back woods. You should come by some time, we can teach you how to play too!
__________________
1983 Thundercraft 16.5 * 1983 Johnson 90 v4 * 1983 Johnson 9.9 * 1965 Evinrude 9.5 * 1955 Evinrude 7.5 * 1951 Viking 3 **Latest-76 Evinrude 15
  #7
Old October 26th, 2009, 09:16 PM
bktheking's Avatar
Ensign
Ok seriously now to answer your question, JB beat me to it, usually I point out the bad punctuation and spelling before he does. You are posting your question to a bunch of retired OMC mechanics and current mechanics who take the time to reply to posts, I guess they just don't like wasting time reading a bunch of run on sentences. Half the time I re read my posts 3 times to make sure all is well, correct grammer and spelling.
To address your issue (and i'm not expert) but I know enough about these motors to warrant some advice. That tube for the telltale travels up to a 90 degree plastic fitting on the powerhead. Not only does the tube get plugged but so does the plastic fitting. First advice anyone on here will give is to replace the water pump, it's the bloodline to the motor. They aren't hard to change and if you search the forums the topic has been covered 100 times.
Cheers
__________________
  #8
Old October 26th, 2009, 09:18 PM
oldrudedude's Avatar
oldrudedude oldrudedude is offline
Quote:
If I had $5 for every time i've wanted to say that............
  #9
Old October 26th, 2009, 10:15 PM
dont fancy playing the banjo but i will bring my washing board we can have a jam lol ps thanks for the advice
  #10
Old October 26th, 2009, 10:21 PM
bktheking's Avatar
Ensign
No worries, wash board LOL, good stuff!
__________________
  #11
Old October 27th, 2009, 02:42 PM
Have now fixed it, back flushed it and took the pipe of and found lot of salt it looks as if the last keeper did not look after it .All smiles now thanks for your advice all
  #12
Old October 27th, 2009, 04:08 PM
jay mendoza jay mendoza is offline
Well, you most likely have quite a bit of salt and corrosion inside the block. It's not too hard to remove the head, and with a 1/8" drill you can clear the water passages of the block and head, probably is going to need a thermostat too, so get a head gasket and thermostat cover gasket and seal. There are also treatments that are supposed to remove salt and corrosion deposits, but in severe cases it's best to clean the block and passages manually.
The rebuke you got surprised me, but rest assured that I don't mind poor spelling.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 120 Cooling Problem DancingPaul Johnson & Evinrude Outboards 14 September 1st, 2009 11:57 PM
50 hp evinrude cooling problem doc1213 Johnson & Evinrude Outboards 2 June 12th, 2005 11:44 AM
86-Evinrude 40 hp cooling problem? Skipmunk Johnson & Evinrude Outboards 9 May 25th, 2005 06:23 AM
cooling problem with 1.5 HP evinrude mikkel_kiilerich Johnson & Evinrude Outboards 2 February 11th, 2004 08:43 AM
9.9 Evinrude cooling problem william =robert1 Johnson & Evinrude Outboards 12 March 4th, 2003 05:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
