Re: yamaha 4 stroke dead cyl./injector
Check plugs, compression, then valves if you get bad compression.
You can test signal to injectors if you have proper equipment.
You might swap injectors to see if problem follows, but if you had bad fuel and you had to clean and replace VST then I would think you have plugged injectors or screens.
