  #1
Old October 25th, 2009, 10:49 PM
bjeppsen bjeppsen is offline
Default Drain plug in pivot howsing
Help, I have a 99 four winns horizon 200 with a volvo penta type DP-SM outdrive. I can't find the drain plug in the pivot housing that the owners manual refers to in the winterization process.
  #2
Old October 28th, 2009, 06:34 PM
Dave1251 Dave1251 is offline
Default Re: Drain plug in pivot howsing
You have to remove the props. The drain plug is behind the inner prop.
  #3
Old October 31st, 2009, 11:03 AM
Lou C's Avatar
Lou C Lou C is offline
Quote:
...if you go to www.dougrussell.com and look in the Volvo parts section there will be parts diagrams and you can see where the drain is on the pivot. My Cobra has 3 drains...on one side there are 2 and 1 on the other side...and you have to tilt the drive up to see one of them. I looked at the one for the 99s and there was no drain on the pivot but there was one on the earlier ones....I wonder if they changed the casting and eliminated that drain plug...it would look like the drain screw for the lower unit..big screw for a flat head screwdriver...
btw...there is also a slot...where the drive bolts to the pivot housing...that has to drain...if it clogs it will crack the housing...so look for the slot (right near the lower edge of the drive where it bolts to the pivot) and slide a very thin screwdriver in to make sure that area drains...or even better...remove the drive check the bellows u-joints and gimble bearing and of course any trapped water will drain out...
__________________
1988 Four Winns 200 Horizon
4.3 OMC Cobra
98 Jeep Grand Cherokee 4.0 Selectrac
07 Jeep Grand Cherokee Limited 5.7 Quadradrive II
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercruiser Alpha One Drain Plug & Vent Plug davemoore Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 21st, 2009 09:44 PM
RDSL-22 Shift Plug (Oops not drain plug) jrpeterson75 Johnson & Evinrude Outboards 11 September 29th, 2008 12:41 PM
drain plug hullken Boat Topics and Questions (not engine topics) 7 May 8th, 2008 03:12 PM
OMC drive fill plug and drain plug> vonway Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 19 July 27th, 2005 03:06 PM
OIL DRAIN PLUG MIKE SMITH Non-Repair Outboard Discussions 1 June 7th, 2002 10:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
