Hello,
Replaced my lower unit seal and after i reinstalled the lower unit i have no reverse ..Forward and nuetral is working fine but when i put it in reverse in goes in forward..can somebody guide me on how to fix it.. i have unbolted and turn the shift rod to the nuetral position servel times and reinstalled ..im sure it has something to do with how i am doing it,
when i had the gears/prop shaft out everthing looks fine ,,springs.gears ..no wear or breakage..only issue i ahd before i started that the lower unit seal (prop shaft seal) was leaking ..
Any advice would greatly be appreciated ..IE PDF instructions
Thanks,
Fisherman without reverse
Thanks,
