Re: How much would you pay?
I bought it. $100 and I pull it from the boat. Guy wasn't really mechanical, so I wound up explaining a lot of the stuff on the engine to him..
New plugs, Comp is 115-119 in all 4, LU oil is clear, shifted & engaged in gear with no extra noise of clunking/grinding. It started right up, although he ran it before I arrived, it was still a little warm to the touch. WP pumps a stream, but not very force full. I had him run it 10-15 minutes & heads still comfortable to touch, no alarm.. OH Sensors were good, not melted as mine became.. It has manual Tilt which is no biggie, my old one was the same, & it makes the install easier.. While idleing, the advance started to increase while sitting there, he pushed it back manually & idle came down. Playing with the linkage at home, I think he must have changed cables & created a problem in the adjustments, and it vibrated up some ..If the throttle is on the stop, the advance roller is pinned in the slotted pathway, which wont allow the advance to move.. This is set by the cable adjustment & Link & sync method, right?
