  #1
Old October 25th, 2009, 05:46 AM
MalG MalG is offline
Exclamation Evinrude 6hp 1976 shaft removal
Hi - I have a 6hp Evinrude 1976 model. I have removed the lower case and discovered that the shaft has snapped where the impeller pin goes in. I have removed the water pump assembly but am unable to remove the shaft. Do I need to do anything more or should it just slide out? Many thanks.
  #2
Old October 25th, 2009, 08:30 AM
Vic.S's Avatar
Vic.S Vic.S is offline
Default Re: Evinrude 6hp 1976 shaft removal
There is a pin through the shaft near the top which has to be aligned with a slot in in the housing before the shaft can be removed.
Turn the flywheel slowly while pulling on the shaft and eventually you should find the point at which it will come way.
See the diagram HERE The pin is #8. It supports all the components #1 to #6 that make up the seal at the top of the shaft.
__________________
If it aint broke dont fix it!
If all else fails read the manual
  #3
Old October 25th, 2009, 01:23 PM
F_R F_R is offline
Before replacing the shaft, check the gearcase and exhaust housing on a surface plate and dial indicator for being bent. If bent, it will snap another shaft. Maybe not today or tomorow, but give it time and enough bends back and forth as it rotates and...
  #4
Old October 25th, 2009, 05:38 PM
Thanks for the replies - I have learned something new. However, I want to remove the shaft from the gear casing as it snapped off at the water pump. It does not seem to want to slide out so I guess there is something holding it in. Thank you.
  #5
Old October 25th, 2009, 06:23 PM
bktheking's Avatar
bktheking bktheking is online now
Ensign
Read what Vic wrote you, you have to rotate the shaft to a point where the pin holding it in will line up with the housing then it should pull upward, look at the diagram he posted, the pin is at the bottom of the shaft. He referred to the pin at the top but there is also one at the bottom, I think it is the same concept for the lower and upper. Never worked on one but judging by the diagram this is how it works.
__________________
1983 Thundercraft 16.5 * 1983 Johnson 90 v4 * 1983 Johnson 9.9 * 1965 Evinrude 9.5 * 1955 Evinrude 7.5 * 1951 Viking 3 **Latest-76 Evinrude 15
  #6
Old October 25th, 2009, 09:23 PM
Vic.S's Avatar
The pin near the bottom of the shaft, #17 in the diagram I gave, is the pump impeller drive pin.
As far as i can see there is nothing retaining the drive shaft in the gear case (no nut on the bottom or pin through the pinion gear so once the water pump housing is removed it should simply pull out.
Apologies for assuming you were asking about removing the shaft from the crankshaft. It's that pin at the top that fools many people when they are trying to remove the gearcase assembly to get to the water pump.
__________________
  #7
Old October 25th, 2009, 09:54 PM
F_R F_R is offline
Agreed, there is nothing holding it into the gearcase. Below the water pump's stainless steel plate is a bearing plate. Remove the bearing plate and you can get a good grip on the shaft and pull it out.
I have a feeling you are going to ignore the advice about checking the housings. Oh well....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
lower unit removal and starter removal 1976 Evinrude 70 hp msu98 Johnson & Evinrude Outboards 2 June 15th, 2009 11:11 PM
Starter removal 1976 Evinrude 70 hp msu98 Johnson & Evinrude Outboards 2 June 15th, 2009 12:09 AM
Evinrude drive shaft removal CL60 Johnson & Evinrude Outboards 9 January 17th, 2008 05:38 PM
Lower unit removal evinrude 75hp 1976 flodan Johnson & Evinrude Outboards 5 April 17th, 2005 08:59 PM
1976 Evinrude 115hp Prop Shaft kpetrossian Johnson & Evinrude Outboards 2 March 30th, 2004 12:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
