  #1
Old October 25th, 2009, 03:13 AM
kmaysob kmaysob is offline
Default 9622a evinrude wont run with cover on
hello all, first time poster here. today i aquired a boat that came with a an evinrude 9622a motor. ser#e05257 it was pretty well taken care of and with a little cleaning up and a new set of plugs i got it to fire up and idle pretty decent. checked the water pump and it works great. so heres my problem it runs great until i put the cover on. seconds after i put it on it starts to die. i cant see anywhere for it to suck air in. am i missing something? also it smokes like crazy. i put a 50:1 mix in. my first thought is maybe its set too rich?
ive worked on alot of small engines but never an outboard. any guidance is greatly appreciated.
i did try to search the problem with the cover and came up with nothing.
thanks in advance.
also, i wasnt able to find a gap spec. so i installed the plugs outta the box
  #2
Old October 25th, 2009, 08:22 AM
JB's Avatar
JB JB is offline
Default Re: 9622a evinrude wont run with cover on
Gap the plugs at .030".
You most likely have an exhaust leak. Fairly common problem with the 9.5s.
__________________
RED SKY at night. . .
JB
  #3
Old October 25th, 2009, 09:45 AM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
Agree with that. It's most likely recirculating the exhaust gas through the intake and it cannot breathe properly.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #4
Old October 25th, 2009, 01:19 PM
F_R F_R is offline
Quote:
If you are trying to run it in a barrel, forget it. They simply will not run in a barrel with the hood on because it breathes it's own exhaust.
However, if you are running it on a boat, that is a different story, and a quite common one. There are several notorious exhaust leak paths that will cause it. The rubber flap seal between the exhaust housing and outer covers is always the first thing to be suggested but usually is NOT the cause.
  #5
Old October 25th, 2009, 01:25 PM
Rick. Rick. is offline
I agree with above but would suggest there is probably no exhaust leak. The problem with 9.5's is they sit low when running in a barrel. One fix is to have a fan blowing at the engine while running. Once you get it on the transom in the water you sill likely find all is well as there is better ventilation and no concentration of exhaust gas. I agree it appears the cowling hasn't enough holes for combustion air but I assure you there is enough. Try it on the lake and see how she runs there. Very important to have the points clean and set at .020. Best of luck. Rick.
  #6
Old October 25th, 2009, 02:21 PM
bktheking's Avatar
bktheking bktheking is offline
Ensign
My 65 will run in a barrel with the cover on, albeit it the rrpm drops when I do put it on. Why do these motors smoke like crazy, my 9.9 doesn't smoke 1/4 as much as this thing, it's always been a question of mine as well.
Not to highjack but same question, smoke screen!
__________________
1983 Thundercraft 16.5 * 1983 Johnson 90 v4 * 1983 Johnson 9.9 * 1965 Evinrude 9.5 * 1955 Evinrude 7.5 * 1951 Viking 3 **Latest-76 Evinrude 15
  #7
Old October 25th, 2009, 03:09 PM
ah i had thought maybe it was just getting smoked out ill have to try the aiming a fan at it or maybe even cut my barrel down to just the right size. i have it mounted on the transom and i just stuck the barrel under it. the barrel is a little tall. thanks for the replies. i will have to gap my plugs and check the point gap. although, usually when the point gap is off isnt it hard to start?
  #8
Old October 25th, 2009, 07:47 PM
gonna check the point gap tomorrow and set the plug gap. anyone know what year this motor is?
also, what is the torque spec. for the flywheel when installing it?
thanks for all the input
  #9
Old October 25th, 2009, 07:49 PM
bktheking's Avatar
Ensign
1966
__________________
  #10
Old October 25th, 2009, 07:50 PM
Quote:
Originally Posted by bktheking View Post
1966
ah that would be why i cant find it on evinrudes site
  #11
Old October 25th, 2009, 07:51 PM
bktheking's Avatar
Ensign
1968 and up, OMC dealers still have everything you need to look up from 67 down.
__________________
  #12
Old October 25th, 2009, 08:01 PM
any one know the flywheel torque spec? i plan to buy the book for this motor soon.
  #13
Old October 25th, 2009, 08:22 PM
bktheking's Avatar
Ensign
My manual goes back to 73, the last year of the 9.5, it calls for 40-45 ft lbs, I don't think the motor changed all that much since 64.
__________________
  #14
Old October 25th, 2009, 09:55 PM
bktheking: re the smoke. Good question and haven't seen an answer. My personal hunch is it's about the compression. 9.5's are a lower compression motor than a 9.9 and my guess is that is why 9.5's appear to burn more oil. The 9.5 (and this is just my experience) uses way more gas so therefore burns more oil all of the time it is running at any speed. Not sure why a gain of 0.4 HP makes such a difference but the 9.9 is faster, more efficient and 25lbs. heavier to boot. It just has to be the increased compression. Rick.
  #15
Old October 25th, 2009, 09:56 PM
hey guys, checked the points, they were spot on. the coils,condensers and points all looked pretty new. adjusted the carb a little bit and stuck it back in the barrel with a fan blowing towards it. put the cover on and she runs like a beauty. now i just need to lube it up and its time to go to the lake! thanks for all the help.
  #16
Old October 25th, 2009, 10:04 PM
F_R F_R is offline
Quote:
Flywheel torque is 40-45 ft/lbs
The 9.5 and 9.9 are totally different motors, related in name only.
On ANY premix two stroke, 100% of the oil that you put in the gas goes through the engine. Some gets burned and the result of that is smoke. The remainder that doesn't get burned goes out the exhaust. Witness the scum on the barrel water. There is no other place for the oil to go, burn it or discharge it. The environmental folks these days have a hissy if they see oil on the water. OR, they have a hissy if they see smoke. There is a way to prevent both---don't start the motor.
  #17
Old October 25th, 2009, 10:09 PM
bktheking's Avatar
Ensign
Hell ya, when I pulled the 9.5 out of the barrel yesterday I could barely see the paint on the lower unit for all the oil. The 9.9, hardly any oil after running it for a whle. I guess it's just an efficiency difference between the older motors vs the newer 2 strokes. Would running synthetic oil in the 9.5 cut down the wasted oil?
__________________
  #18
Old October 25th, 2009, 11:05 PM
F_R F_R is offline
I don't care if you put moose milk in it, it still goes through the engine along with the gas, so "wasted" is not a good word. However, your question is a good one. 100% synthetic TC-W3 oil creates much less smoke and less oil sheen on the lake, which also dissipates faster. And it is bio-degradeable. It is all I ever use any more. But any oil makes scum on the barrel water because it is so concetrated.
Yes, newer motors are more efficient. In fact the 9.5 and other motors of the era deliberately dumped excess raw gas from the puddle drains directly overboard. Some of them in huge amounts. The puddle drains were eliminated on newer motors.
  #19
Old October 25th, 2009, 11:10 PM
bktheking's Avatar
Ensign
Ok, thanks for answering, I am going to switch to 100% synthetic, although I am not a tree hugger per se, I do take notice on how much these 2 strokes puke oil, especially the older motors and I have 2 young kids that need to live here after i'm dead and gone!
__________________
  #20
Old October 25th, 2009, 11:26 PM
crxess crxess is offline
Not to knock on anyone, but both my '67 9.5 and '73 6h.p. run pretty clean for a 2 stroke. Very little smoke running Valvoline or Tech twc-3 oil 87 octane gas at 50:1. I do keep the low speed adjusted tight and don't let it just sit idling for long periods.
  #21
Old October 26th, 2009, 01:47 AM
kmaysob: Great to hear of your success. A couple of things I would recommend. A new impeller as soon as you can get one, unless you are aware of the last time it was changed. I would also recommend changing the leg oil. Other than that, have lots of fun with it, they are good motors and very dependable.
F_R: Moose Milk!! You've made me laugh out loud again. Thanks for your insight and as always, your sense of humor. Rick.
  #22
Old October 26th, 2009, 02:05 AM
i had planed on changing the lower end oil. i didnt think of the prop.
ill have to look for one. it probably is ok. it came from a co worker who took pretty good care of this motor. any way to tell if i need to replace it?
  #23
Old October 26th, 2009, 11:58 AM
Don't change the Prop, I said impeller. The impeller is the life blood of the cooling system and should be replaced every two to three years. You can't tell by looking at them if they are going to fail, only that they have failed which is too late for your power head. Changing the impeller is preventative maintenance. Rick.
  #24
Old October 26th, 2009, 02:05 PM
idk why i automatically thought the prop. yes the impeller.i priced that out the day i got it. thanks for the advise.
  #25
Old October 26th, 2009, 05:39 PM
jay mendoza jay mendoza is offline
One thing I know that makes all 2-strokes smoke is stuck compression rings. On most 2-strokes with 2 rings, the second ring will get stuck with carbon and varnish in the ring grooves.
The second thing I have seen that makes 2-strokes smoke badly is blocked exhaust. Although this is rare in outboards, it can happen, especially if someone ran too much oil in the gasoline, or used motor oil in place TC-W rated oil.
Prolonged idling will cause the cases to load up and the engine to smoke. Over cooling, (thermostat stcuk open) will cause excessive smoking, And the idle mixture(low speed) set too rich can cause excessive smoking.
A propoer de-carb treatment will unstick the rings, and usually reduces smoking and increases compression slightly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Use 1998 Evinrude 90hp power trim on 78 evinrude 85hp? Andy_KZ Johnson & Evinrude Outboards 2 May 29th, 2009 05:08 PM
Evinrude 1990 Evinrude 150 lower unit metallic powder on plug brewhaha Johnson & Evinrude Outboards 3 April 7th, 2009 10:21 AM
are 1982 70hp Evinrude parts interchangeable with a 1983 70 Evinrude cassfam7 Johnson & Evinrude Outboards 1 April 15th, 2006 12:48 PM
evinrude model 9622a 9.5 sportwin bondo59715 Johnson & Evinrude Outboards 1 August 8th, 2003 06:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
