  #1
Old October 24th, 2009, 09:56 PM
trendsetter240 trendsetter240 is offline
Default 95 Evinrude 70 Pitting in head and grooves in #1 cylinder
I picked up a 1997 Evinrude 70 HP. The PO said that the top cylinder had some grooves in it and he didn't want to rebuild.
I popped off the head and had a look. I found that there was indeed some minor grooves in the top cylinder. There was tons of carbon buildup but the piston looked ok. The rings are still intact though one might be sticking.
The other two cylinders look fine, however. The middle cylinder head has some pitting in it. (see picture below). But the cylinder looks perfect.
What would be your advice on this motor: Should I tear it right down and hone/rebore, new pistons and rings and have the head polished?
Or would it be okay to leave until next season? Maybe just have the head machined for this season?
Any advice much appreciated.
  #2
Old October 24th, 2009, 11:22 PM
R.Johnson R.Johnson is offline
Default Re: 95 Evinrude 70 Pitting in head and grooves in #1 cylinder
Look's like something loose in there, probably a broken ring,
  #3
Old October 24th, 2009, 11:40 PM
oldrudedude's Avatar
oldrudedude oldrudedude is offline
Did you do a compression test? What numbers did you get?
  #4
Old October 25th, 2009, 12:06 AM
No i didn't do a compression test. It was a spur of the moment buy. The guy only wanted 200 bucks for it and it's in like new condition apart from the problems mentioned above. (it also came with new controls, cables and oil tank)
Do you think I should put the head back on and test the compression?
At this point I'm leaning towards a complete tear down and rebuild.
  #5
Old October 25th, 2009, 03:41 PM
Post Re: 95 Evinrude 70 Pitting in head and grooves in #1 cylinder
Ok. I put the head back on and tested the compression:
#1 = 55PSI
#2 = 110PSI
#3 = 115PSI
Looks like it's time for a rebuild.
Any advice on what will need to be done with the cylinder head shown in the pic in my first post? Can it be honed to remove the pitting or will i need a new one
  #6
Old October 25th, 2009, 04:10 PM
bktheking's Avatar
bktheking bktheking is offline
Ensign
The pic was of the top of the piston, doesn't show the sidewall of the cylinder so hard to say.
__________________
1983 Thundercraft 16.5 * 1983 Johnson 90 v4 * 1983 Johnson 9.9 * 1965 Evinrude 9.5 * 1955 Evinrude 7.5 * 1951 Viking 3 **Latest-76 Evinrude 15
  #7
Old October 25th, 2009, 04:19 PM
Quote:
Sorry, I went for a close up picture and I guess it's hard to tell where it is.
The picture is of the cylinder head after I removed it from the block. The image is zoomed in on the #2 section of the head. The hole you see in the middle is the spark plug hole from the inside.
Here is the full picture of the head but it's hard to see the pitting from this distance.
  #8
Old October 25th, 2009, 06:38 PM
As I said, something has come apart. I doubt if Sea Foam will fix that.
  #9
Old October 25th, 2009, 06:42 PM
Quote:
You're right. I am going to be rebuilding it. I've already started pulling apart the powerhead.
My question still is what needs to be done with the pits in the cylinder head as shown in the pictures?
  #10
Old October 25th, 2009, 06:45 PM
bktheking's Avatar
Ensign
OK, so that was the head, duh im slow. The motor has to come apart to see what is going on, as rjohnson said, broken ring maybe. You could pull the side covers off of it to get somewhat of look at the rings but it won't show cylinder damage if a ring did indeed break. Get yourself a good manual and start wrenching away until you find out how bad it is.
__________________
  #11
Old October 25th, 2009, 06:48 PM
bktheking's Avatar
Ensign
Plan on finding yourself a used cylinder head for that motor. Now you can rotate the flywheel and check the walls for bad scratches and pieces of ring, you may be getting into some $$$ here.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
pitting in the head cadilacboat Johnson & Evinrude Outboards 4 June 13th, 2009 06:23 PM
Odd feeling cylinder head bolt while torquing cylinder head onto Chevy 350. rs2k Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 12 May 24th, 2009 02:01 PM
Power Head Corrosion and Pitting on the block deck Jaker34 Johnson & Evinrude Outboards 4 March 17th, 2009 11:34 PM
Evinrude Cylinder Head Removal Markus Miller Johnson & Evinrude Outboards 4 August 7th, 2006 11:59 PM
Evinrude Cylinder Head snert21 Johnson & Evinrude Outboards 4 August 13th, 2002 04:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
