  #1
Old October 24th, 2009, 07:19 PM
DuckSlayer84 DuckSlayer84 is offline
Default 94' 50hp Evinrude Bogging at high rpms
Not sure what the problem is. I have a 94' 50hp Evinrude that was just recently rebuilt. Got it back from the mechanic telling me everything was right, turns out that he lied, big surprise there. The problem is when I try to give it full throtle it will do fine, get up and go perfect, for about 5-15 seconds depending on whatever, and then it starts to lose power and boggs down. The only way i have found to keep it at high rpms is by pumping the key to choke it. I have to pump the key about every 2-5 seconds to keep it going or else it will just bogg down and i will come off plane. What is wierd is that when i run at mid rpm's she seems to do fine. It just seems to be that higher rpm range that gets it. The kicker is when it starts to bogg i can't just run at mid rpms i have to stop, cut the engine and wait a min or too. Only otehr info i have is that it use to have a VRO pump which the mechanic removed and put in a holly inline gas pump. I replaced all the fuel lines up to the engine and have 2 inline fuel filters. Any idea's?
  #2
Old October 25th, 2009, 07:09 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 94' 50hp Evinrude Bogging at high rpms
fuel starvation, either clogged high speed jets, weak fuel pump, partially clogged fuel tank pickup tube filter.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old October 25th, 2009, 02:16 PM
Brand New 6-Gal back-up tank is being used to isolate problems. It has a brand new Holly inline pump. Would cleaning the jets be a do-it-yourselfer if you have a good mechanic ability. Never done it but how hard could it be? If so where might i find a guide. Thanks
  #4
Old October 25th, 2009, 11:30 PM
lovemywife's Avatar
lovemywife lovemywife is offline
Quote:
Sounds like mine I replaced all the fuel lines removed and cleaned all three carbs. Put it all back togather, pumped the ball until it was firm. Then I noticed the filter by motor was not filled with fuel. Short verson it was the ball something inside was not letting fuel out. Runs great now. I would have never noticed if I had not removed all the fuel lines which emptied the filter.Hope this helps
__________________
Your making the wrong assumption that a MARINE by himself is outnumbered!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 70hp evinrude high rpms mandyman1345 Johnson & Evinrude Outboards 8 August 23rd, 2009 10:14 PM
Evinrude 50HP bogging when under high RPM Load rebelyel77 Johnson & Evinrude Outboards 2 June 22nd, 2007 09:41 AM
1977 55hp Evinrude is bogging down at high RPMs ? 103Control Johnson & Evinrude Outboards 6 July 26th, 2006 10:14 PM
50hp johnson high speed alarm, bogging ne-boater Johnson & Evinrude Outboards 8 July 13th, 2006 09:26 PM
70 hp Evinrude bogging out at 2000 rpms sjames Johnson & Evinrude Outboards 4 August 16th, 2004 10:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
