  #1
Old October 24th, 2009, 02:31 AM
crackedglass crackedglass is offline
Default Mercury two cylinder compression comparison?
I have two Mercury 40 HP twin cylinder engines. One is a 1971, the other a 1985. The 1971 gives me a compression reading of 145/147 on both cylinders, the 1985 shows only 122/122? Both motors are well maintained freshwater run motors, both seam to run great. The reason for my concern is that all of my other Mercury motors show in the 140 to 150 psi compression range on all cylinders. But this recently acquired motor shows less.
I'm just curious if they lowered the compression or could this motor be just weak? Running wise it gives me no reason for concern, but since I was checking the plugs and winterizing it, I figured a compression check was in order.
Do you think that this motor may be 'well worn' or is it normal compression findings for such a motor?
I realize that all that realy matters is that the cylinders are all within 5 or 10% of each other but what constitutes to much wear or noticable wear?
  #2
Old October 24th, 2009, 03:06 AM
northernmerc northernmerc is offline
Default Re: Mercury two cylinder compression comparison?
That compression sounds OK. I have a '78 Merc 40 hp with about 130 psi compression on all cylinders and a Johnson 30 that is at about 120 psi. One hears about motors with compression below 100, and the owners don't seem concerned.
  #3
Old October 24th, 2009, 08:41 AM
JB's Avatar
JB JB is offline
Both engines are just fine, CG.
The owner appears to be suffering from psi paranoia.
__________________
RED SKY at night. . .
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Low compression 1 cylinder 88 Mercury 60HP SMOKNZ Mercury & Mariner Outboards 3 May 21st, 2008 12:57 AM
'92 135HP Mercury - no compression in one cylinder TimS Mercury & Mariner Outboards 14 July 24th, 2003 03:51 PM
Mercury 115 low compression top cylinder medic28640 Mercury & Mariner Outboards 1 June 14th, 2003 11:21 PM
89' Mercury 115. #3 cylinder no compression.HELP 2738 Mercury & Mariner Outboards 6 March 3rd, 2003 02:50 PM
mercury 115 low compression one cylinder - HELP alvin Mercury & Mariner Outboards 13 February 27th, 2002 10:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
