Maddoxsdaddy
- Sep 22, 2008
- 222
I have a 1995 Astro fish-n-ski with a '94 Mercury 115hp.
First issue... The past 3 times its been out, it's had trouble turning over. The starter is barely turning the motor over at first but after a few attempts, it picks up and turns over fine. The battery is fully charged... Is the starter worn out or is it something else?
Second issue... This past weekend, the high heat/low oil light and alarm came on while pulling a tuber so i immediately turned off the motor. I checked the oil level (again) which was at half a tank so i thought it may have overheated. Started again, motor ran for a couple of seconds then cut itself off. Am i looking at the oil injection system fouling up?
Thanks,
TB
Thanks,
TB
