davio47
- Aug 29, 2009
- 31
I just bought this motor. This motor sat in a basement for 3 years. I have run it in a barrel and it runs nice. The motor exhibits a strong flow of water from the rear port and indicator tube. The water pump seems to be working fine. This motor was used primarily in the Chesapeake Bay on a Dingy. My concern is the possible corrosion in the water jacket and its effect on the thermostat operation. Is this something I should be concerned about and pull the head and replace it? If the thermostat fails or clogs would this cause a over-temp condition? If fails would it usually fail open? Interested in your thoughts on this.
Thanks,
Dave
Thanks,
Dave
