old850merc
- Sep 7, 2009
- 2
it's that time again, I have an 850 merc 1974 and it refuses to start in cooler weather. Starts great in warm / hot weather when engine block is warm. no problem, starts right up, runs good. its now 75 degrees and cooler at night, when i feel the engine block its cool, figured I'd have a problem and sure enough, turns over, spins, but won't fire up. In the past (just didn;t do it today as I'm now in a marina without access to electric) i'd put a heat gun blowing on the motor to heat up the engine block, took anywhere from 15 minutes to 30 minutes, once warm, turn the key and bang, starts on first crank after trying for many long attempts just before that. Any ideas? someone sugested the magneto needs to be warm to expand contacts to fire it? much appreciate any help, it's been 10 years this way, no problem before as I would pre heat motor in cooler / cold weather but now in a marina with no access to electric. thanks, Bill
